paul_mcq
| posted on 2/1/04 at 02:37 PM |
sierra v6
can the 2.9lr be used or is it to heavy for its own good?
kingr
| posted on 2/1/04 at 02:53 PM |
You can make it fit, but yes, it is rather heavy. It's not an engine that I would go for were I not building a BEC - Rover V8s are more popular,
have more tuning parts and services available and are unlikely to be signifcantly more hastle, I also suspect that they're quite a lot lighter
being largely alloy.
Doubtless Mr. Gusty will have more to say about this, but I'll try to pre-empt him by saying a) his isn't really a locost b) the more you
deviate from the book, the longer it takes (and yes, trying to make an injected, Ford V6, ABS equiped Morgan-a-like is deviating quite a lot).
Kingr
liam.mccaffrey
| posted on 2/1/04 at 03:24 PM |
sierra v6
I initially thought I might use v6 as in granada/sierra but insurance is very steep for such a low power engine (150 BHP IIRC)
From what I gather there are a lot of better options in the form of better V6's/V8's (RV8, cosworth 24v) and equally powerful smaller
lighter engines (4age)
I believe sierra v6 is better with twin turbo conversion but these quite rare.
blueshift
| posted on 2/1/04 at 04:02 PM |
I don't know about prices for 4AGE and things like that, but the sierra v6 has the advantage that you get one in your sierra donor, so you can
pull out all the wiring and ancillary bobbins at your leisure as you strip the car. Plus they can be had for cheap if you're lucky (our donor
car with a 2.9 v6 in it cost £10).
Downside, I think all the ones in sierras are 4x4 so you need a gearbox and sump from somewhere else (capri)
sg_frost
| posted on 2/1/04 at 09:40 PM |
Mines got a 2.8 V6 in it, big bulge needed in the bonnet though, or a taller chassis.
Need a gearbox from a V6, normal sierra box will not fit cause input shaft is longer on V6!
Late ('92) XR4x4I have no air flow meters and lower inlet manifolds. Unfortunately, finding a '92 XR is not easy, I had one though
Check out the photo section.
stephen_gusterson
| posted on 3/1/04 at 12:01 AM |
I think you said it all!
thanks for listening and taking note
Kingr
