mikeb
posted on 2/9/08 at 05:12 PM |
Exhaust Manifold
I currently looking at some locost ways of sorting my exhaust system out but still want it to look ok quality.
I seen to have four options
1. Westfield or MK new manifold ~£250, looks good but too expensive
2. An old westfield race manifold but needs collector not sure how it will exit the body work and the ease of welding a collector on>
3. This one on ebay for around £100 delivered but no sure about it, thoughts welcomed.
http://cgi.ebay.co.uk/ZETEC-CUSTOM-TUBULAR-MANIFOLD-KIT_W0QQitemZ370071341841QQihZ024QQcategoryZ72205QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Mike
![](/galpreviews/a800280-exhaust 1.jpg) ![Rescued attachment exhaust 1.jpg](/gallery/a800280-exhaust 1.jpg) Rescued attachment exhaust 1.jpg
jacko
posted on 2/9/08 at 05:46 PM |
Hi Tim windmill on here bought a westfield manifold and its very good for the money
Jacko
lotusmadandy
posted on 2/9/08 at 06:47 PM |
Mike,
i like the one on ebay.i am changing from a pinto to a zetec soon and think i will be tempted by one.shame it's not in stainless
though.![](/images//smilies/bigsmile.gif)
posted on 3/9/08 at 08:16 AM |
Zetec flanges are available and tons of places sell mandrel bends.
If your canny with the mig or have gas its very possible, just takes ages... but time is free![](/images//smilies/bigsmile.gif)
OR, how about a standard Focus tube type manifold cut and shut??
Summit like this?
Focus
[Edited on 3/9/08 by coozer]
scutter
posted on 3/9/08 at 08:49 AM |
A friend has 2 St170 manifolds, which if i'd known about earlier i'd have cut and shut myself.
ATB Dan.
cliftyhanger
posted on 3/9/08 at 09:30 AM |
Will those "ramhorn" type ones or fleabay fit with a raceline water rail?
Or how about this
http://cgi.ebay.co.uk/New-Ford-Zetec-2-0-ltr-Exhaust-Manifold_W0QQitemZ200250573247QQcmdZViewItem?hash=item200250573247&_trkparms=39%3A1%7C66%3A2%
7C65%3A1%7C240%3A1318&_trksid=p3286.c0.m14
Clive
[Edited on 3/9/08 by cliftyhanger]
jamie1107
posted on 3/9/08 at 11:49 AM |
manifolds arnt simply 4 random tubes bent to roughly the right length
if you have a tuned engine or even of you do not its worth either talking to a specialist or doing the math yourself to work out your primary and
secondary pipe lengths and diameters to get the power you want from your engine where you want it off the shelf manifolds often restrict engines when
you run them up on a dyno if you cant stretch to a custom build i would just stick with the factory manifold where this has already been done for you
and match the ports it may be a mass production item but at least it is designed to give useable power and torque
vinnievector
posted on 3/9/08 at 12:09 PM |
save
save the pennies for a stainless one mk or westfield, but if you need to get it going use the old manifold for now
cliftyhanger
posted on 3/9/08 at 01:59 PM |
That is a very sensible approach, so much "tuning" stuff makes cars slower. I suspect the st170 manifolds are good IF you can keep the
dimensions the same when altering.
Unfortuanately my car has very litited space, and a raceline water rail. My Homemade manifold works, and I got the primaries all the same length, but
I have no idea how good it is. The other alternative I have got is a mondeo Duratec manifold, and it would not be too hard to swap the flanges over as
the pipe spacing is VERY similar. Again diffeent engine so will not be perfect, but should be pretty good. It has similar length primaries to the one
I made.
But the "ramhorn" style ones would be good in terms of space......
So does the focus one fit with the water rail??
Clive
