philhoward
| posted on 7/9/08 at 11:15 AM |
Weber Accelerator pump
I am running twin 45 Webers on a 2lt Pinto. When I floor the accelerator the engine dips before taking off. Would I be right in thinking that the
accelerator pump is a bit sticky and needs cleaning or changing.
Normal gradual acceleration is ok through the range, it is only when I floor it.
jamie1107
| posted on 8/9/08 at 02:48 PM |
take your filters off and pull or push cant remeber which way they go think its pull on the levers if it squirts fuel in on both then there working
next thing to check would be that the cam s are working them properly
