Author: Subject: Crank shaft puley
paulbeyer
posted on 14/7/02 at 09:54 PM Reply With Quote
Crank shaft puley
Anyone got any bright ideas on how to remove the small crankshaft pulley on a 2.0L pinto? I want to replace the oil seal behind it but it is stuck like a bastard. I've tried marinating it in WD-40 for a few days, but it still won't budge. It it surrounded by some wierd looking cast alloy casing so I can't get any leverage behind it and with that being the case I don't see how I would be able to get the arms of a puller behind it either. All the Haynes manual says is "undo the bolt and remove the pulley by hand" yea right.
posted on 15/7/02 at 08:03 AM Reply With Quote
Do you really mean the crankshaft, or are you talking about the water pump pulley (a well-known bastard to remove). It's the 'alloy casting' bit that makes me think this!
If it is the water pump pulley, then (a) it's a left-hand thread, and (b) you'll need to make or buy a special 'skinny' spanner to reach behind and get a good grip.
If it isn't this pulley, just ignore my ramblings!
theconrodkid
posted on 15/7/02 at 05:36 PM Reply With Quote
the pullys can be tight just gently tap it with a copper and hyde hammer,it will come off,swearing usually helps as well.
paulbeyer
posted on 17/7/02 at 08:53 PM Reply With Quote
I still can't get that fu**ing crank shaft pulley off the bastard engine. there's no where to hit it with a hammer and I cant get a lever behind it because it is surrounded by some sort of cast alloy wank poo bastard casting. Come on guys, someone must have been in a similar situation before, any takers?
johnston
posted on 17/7/02 at 09:54 PM Reply With Quote
scare it by tellin it your goin to burn the bastardin thing it'll come off in minutes.
(usually works for me)
James
posted on 18/7/02 at 02:04 PM Reply With Quote
I have exactly the same problem myself at the moment with my SOHC.
Heynes says something helpful like: "Remove the bolt" (this took me ages as couldn't stop pulley turning) "and then remove pulley. On injection engines a puller will almost certainly be needed".
So presumably it is possible to use a puller and looking at it I can't see any reason why not. I can't see that the alloy casing would get in the way of the puller.
James
paulbeyer
posted on 18/7/02 at 09:04 PM Reply With Quote
Hi James, Thanks for the reply. Are there different versions of the haynes manual? If so I must have the limited edition information not supplied version. All it says in mine is undo the crank shaft pulley bolt and remove the pulley by hand. If a puller is mentioned in your book then it must be possible, but I must admit it looks tight.
I'll visit my local Ford dealer and see what they suggest.
Max
posted on 19/7/02 at 02:15 PM Reply With Quote
I frequently have this problem with the Rover V8 front pulley. My foolproof solution is to bolt a 7 foot bar to the flywheel, heat the front bolt to red hot and let it cool slowly, it normally shifts easily then. However, this method is fine on the RV8 because the pulley and bolt absorb most of the heat and the alloy timing cover stays reasonably cool. If you have got some sort of alloy casing in the way be VERY careful as alloy doesn’t glow red before it melts….
Is the engine in a car or the Locost? If so the other trick is to put a breaker bar and socket onto the nut, bracing it against the floor and give the starter a quick flick. This method has never failed in the past, but I wouldn’t recommend trying it with the engine not properly mounted.
“A little knowledge is a dangerous thing” – By this definition I’m lethal.
James
posted on 19/7/02 at 05:22 PM Reply With Quote
You know something John? I wish you'd stressed the word gently a little more. Possibly with a few stars around it or something.
I still have the pulley attached to the crankshaft....
...but unfortunately I now need a new pulley!!
Oh well, these things are sent to try us!!!
Paul, let that be a warning to you!!!
James
posted on 22/7/02 at 07:54 AM Reply With Quote
I had a look at my X-flow yesterday - I now know that I was talking gibberish previously (no change there )
I prised mine off with a couple of levers, but it wasn't very tight.
At least you have an opportunity to replace it with a machined steel pulley that won't burst at 8K rpm!
James
posted on 22/7/02 at 11:32 AM Reply With Quote
Right, it's possible to get it off with a puller- I know as that's what I did at 1am last night!
It took about 30 seconds! As oppsed to 30 minutes with a hammer!
Pity it took me breaking the current pulley to realise that!
Seeing as I'm fitting a Pinto somehow I can't really see me ever discovering whether it'll do 8K rpm or not!
Not untill I've got all the mods done to it anyway!
James
