Author: Subject: Do CVHs normally smell?
TimC
posted on 8/9/08 at 08:24 AM Reply With Quote
My 1600CVH whifs whenever it's hot. Is this normal?
whitestu
posted on 8/9/08 at 08:30 AM Reply With Quote
What of!!
Davey D
posted on 8/9/08 at 08:35 AM Reply With Quote
If it smelled of strawberries id be more confused than worried
TimC
posted on 8/9/08 at 08:57 AM Reply With Quote
Hot oil.
Paul TigerB6
posted on 8/9/08 at 09:17 AM Reply With Quote
Originally posted by whitestu
What of!!
The CVH is getting on a bit now...........maybe it smells of wee.......
posted on 8/9/08 at 10:23 AM Reply With Quote
Smells of hot oil when its hot eh? How hot? Too hot? Overheating? Bacteria in the coolant?
Oil leak thats burnong off somewhere? Exhaust?
will121
posted on 8/9/08 at 12:02 PM Reply With Quote
if it smells oily when hot, initial things to look at is breather pipes, do you vent breathers to atmosphere or into air box? if vent to air and engine getting worn, could just its now breathing to much.
jambojeef
posted on 8/9/08 at 03:20 PM Reply With Quote
Very common on CVHs is the valve stem oil seals which would also show up as smoke on start-up.
If it could be this they are very easy to do and pence to replace - not a head off job if you buy drapers little tool to compress teh spring against the rocker mounting.
scotty g
posted on 8/9/08 at 07:33 PM Reply With Quote
The CVH smells of poo because thats what its made of!
Detestable damn things!
Can you tell i don't like them?
