Author: Subject: Threaded hole on bottom of Webers
greggors84
posted on 11/9/08 at 06:21 PM Reply With Quote
Cleaning up my weber DCOE 45s and noticed there is a threaded hole on the bottom with nothing in there on the trumpet side.
The carbs do work fine but leak a bit of fuel, ive changed all the gaskets but wondered if maybe there is meant to be a screw in here. Ive looked at the exploded diagra, but its from the top so cant see anything. Rescued attachment 11092008.jpg
Chris
The Magnificent 7!
Mr Whippy
posted on 11/9/08 at 07:24 PM Reply With Quote
can't see any thing that looks like it should go in there
possably a handy page
http://www.tjwakeman.net/TR/WeberDCOEinfo.htm
still nothing in the hole...
[Edited on 11/9/08 by Mr Whippy]
Paul TigerB6
posted on 11/9/08 at 07:52 PM Reply With Quote
As above i dont remember ever having seen anything in that hole. Is it a blind hole then or open??
So where do the carbs leak fuel then?? You havent got sticking needle valves / floats have you meaning the carbs are overfilling?? Guess this is a possibility if the carbs have stood with fuel in them for a while
