Wells
posted on 15/9/08 at 08:56 PM |
Clutch !!!!!!!!!!!!!!
After bleeding my clutch it works perfectly for 5-10 miles. Then the pedal starts to lose pressure until I have no clutch atall. I have repeated the
bleeding process more than 10 times now and I can find no leaks. Any help would be much appreciated as this is now doing my head in!!!!!!!!
Paul TigerB6
| posted on 15/9/08 at 09:05 PM |
Have you tried wedging the clutch pedal down to see if it loses pressure gradually and isn't down to it boiling the fluid up?? It does sound
like a leak though doesn't it!! Try leaving some paper under the car while you wedge the pedal down.
blakep82
| posted on 15/9/08 at 09:18 PM |
somebody else had the same problem a few weeks back... buggered if i can remember what it was though. exact same symptoms i think.
________________________
Paul TigerB6
| posted on 15/9/08 at 09:20 PM |
this one??
Wells
It isnt boiling the fluid as the clutch fluid isnt in contact with anything hot. Iam sure it isnt a leak but I think I will give the clutch wedging
idea a go. Any other ideas are still more than welcome.
blakep82
| posted on 15/9/08 at 09:22 PM |
this one??
lol thats one of them. i think there was another about the same time too, coz i remember him saying the same thing about it being ok, and driving
10miles and it not workoing again
Wells
| posted on 16/9/08 at 09:40 PM |
Any other ideas?
omega 24 v6
| posted on 16/9/08 at 09:55 PM |
Master or slave cylinder seals??
hughpinder
| posted on 17/9/08 at 07:13 AM |
Someone Who works here had a brand new focus with similar problem - it was the hydraulic hosa blowing up like a baloon!
Hugh
| posted on 17/9/08 at 05:51 PM |
Sounds like the master cylinder internal seals have had it, may not have any external leaks with this fault. New seal kit or master cylinder required
Wells
posted on 17/9/08 at 10:33 PM |
Thanks for your help guys I think its time for a new master cylinder because I have replaced everything else.
