jnormandale
| posted on 17/9/08 at 08:38 PM |
Throttle Bodies
I am restricted to space within my chassis. What is better to fit blackbird throttle bodies or gzxr.
Some told me that the length of the port between the trumpet and head matters for performance. I am not that clued up on engines, does this matter?
[Edited on 09/12/2007 by jnormandale]
big_wasa
| posted on 17/9/08 at 08:45 PM |
The intake length can have huge affects on power and how it is delivered.
The zetec is said to need a long intake length to give its optimum performance.
Whats the engine ?
jnormandale
| posted on 17/9/08 at 08:47 PM |
1.6 Petrol Zetec R.
big_wasa
| posted on 17/9/08 at 08:55 PM |
Zetec E or SE ie iron block or the all alloy one ?
Blackbird Tb's are a bit on the large side arnt they ? I would think that would be a bitch to get to idle properly ?
jnormandale
| posted on 17/9/08 at 09:03 PM |
Zetec E. What is smaller GSXR or blackbird throttle bodies?
whitestu
| posted on 18/9/08 at 08:06 AM |
Interesting - my bike carbs are pretty much bolted straight to the head!
Stu
Myke 2463
| posted on 18/9/08 at 01:03 PM |
GSXR 600 very compact, looking down the throat only 85mm and approx 140 high inc injectors.
Mike.
| posted on 18/9/08 at 04:26 PM |
I don't wish to be rude but the 1.6 Zetec E is rather restricted by valve sizes, putting bike carbs or throttle bodies on it isn't going
to gain you a huge amount. The 1.8 or 2.0 engines would make far more sense.
GSXR750/1000 or Blackbird throttle bodies will be far too large on a standard engine, something off an older 600cc bike should be closer.
Jenko
| posted on 19/9/08 at 10:42 AM |
As mentioned, you need to be going as small as possible for a 1.6.....GSXR600 will be perfect......they are 38mm diameter
Better to get the older ones that can be spaced......
The inlet lenght is important, but...For most of us whith kit cars, we do not have the luxury of being able to tune this......
If you don't mind a cut out in the bodywork, then it doesnt matter.....
I'm assuming you are going from a single TB, and the car is currently injected?....So you may need to get an inlet manifold fabricated.......
A pic of the engine bay would be useful, so we can help.
But fyi.....Here is a pic of my car (with a CVH engine), with GSXR600 TB's...
Click
Click1
martyn_16v
| posted on 19/9/08 at 12:41 PM |
Ideal port length for the average car engine is in the region of 18-24". Obviously this just isn't going to happen in your average seven.
