Author: Subject: Ford essex v6 and type 9??
Danozeman
posted on 21/9/08 at 08:39 PM Reply With Quote
Evening all. Would anyone know if a type 9 will go onto an essex v6??
The reason i ask is my mates got a 73 reliant scimitar with an auto in it and a manual is preferred. Especially as im thinking of having it.
Dan
Alfa145
posted on 21/9/08 at 08:42 PM Reply With Quote
I asked something similar recently..
Should find your answer here http://www.locostbuilders.co.uk/viewthread.php?tid=93507
Rob
Danozeman
posted on 21/9/08 at 08:48 PM Reply With Quote
Do nicely thanks mate.
Less agro to put an RV8 in it...
Dan
Alfa145
posted on 21/9/08 at 08:50 PM Reply With Quote
Be easier to just stick the standard type 5 on it.
meany
posted on 21/9/08 at 09:18 PM Reply With Quote
i agree, easiest would a type 5...are they only 4 speed?.
http://www.zetecinside.com/xr2/gearbox.shtml
mr henderson
posted on 22/9/08 at 07:08 AM Reply With Quote
4 speeds are not too bad, especially if it's a decent sized engine. Main question is, is the final ratio correct for a direct top gearbox?
John
mcerd1
posted on 22/9/08 at 07:35 AM Reply With Quote
if you get the type 5 from a scimitar they often have an overdrive box - effectivly a 6 speed....... (sort of)
Danozeman
posted on 22/9/08 at 04:03 PM Reply With Quote
Im not bothered about the overdrive.
LOoking at that zetec inside site i hadent considered putting a zetec into it, Maybe thats an option as im not sure if the engine is any good or not yet.
MMM maybe a carb'd 2 litre zetec is an option.
"" Stop it Dan you havent finished your locost yet """"
posted on 22/9/08 at 05:41 PM Reply With Quote
IIRC the 2.8 Capri used a type 9 , may be of use if you can find one?
mcerd1
posted on 23/9/08 at 07:53 AM Reply With Quote
the 2.8 / 2.9 V6's are different from the older essex 3.0 V6's
but lots of people have fitted the 2.8/2.9 in a scimitar (the later ones had a 2.8 the same as the capri's)
I had the same thought about using a 1.8/2.0 zetec, but the V6 sounds right
I guess you can modify the bulkhead if needed, but I know you've got to watch the length of the engine as the steering rack etc gets in the way
MakeEverything
posted on 4/10/08 at 09:19 PM Reply With Quote
The Essex 3.0 and Cologne 2.8/2.9 are different bellhousings. The cologne will fit a type 9 as rusty nuts says as the capri was fitted with one.
Kindest Regards,
Richard.
