Author: Subject: dipstick tubes come out :S
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 22/9/08 at 05:08 PM Reply With Quote
Well, the area around the bottom of the dipstick 'tube' had been leaking a little oil for a while now, it became a bigger issue on a trackday. So i decided to have a look at it - went to pull out the dipstick and and the whole lot came away from the engine block!!
So, my question is what is best to get it back in place. Do i just use some araldite or is there someting in particular i need to use or do i actually need to fix something??
All help appreciated as usual
Some pics to make it clear whats going on
delboy
posted on 22/9/08 at 05:18 PM Reply With Quote
yes, araldite will do the job fine.
RichardK
posted on 22/9/08 at 05:23 PM Reply With Quote
Usually a friction fit, I would see if I could flare it out a bit and thouroughly clean both sides but uderstand the sump end maybe difficult to degrease, cotton buds?? then chemical metal it in, I also made a bracket that goes onto one of the bell housing bolts and stop any flex in the dipstick tube.
Like this
Cheers Rich
Gallery updated 11/01/2011
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 22/9/08 at 05:28 PM Reply With Quote
yes, was thinking of making a bracket to restrict movement, so thanks for that.
I'll degrease it best i can and flare it for a tight fit and use some araldite to fill the gaps.
Thanks for the help and quick replies, means i can go and sort now rather than later
Cheers again matt
Richard Quinn
posted on 22/9/08 at 06:00 PM Reply With Quote
Like this
Cheers Rich
Sorry for the hijack - What fittings have you used on your ally catch can (I have a very similar set up for my expansion bottle)
RichardK
posted on 22/9/08 at 08:41 PM Reply With Quote
Them euro type air compressor fittings, be warned though getting a half nut on the back was a right sod, bent thick welding wire twisted round the edge to hold in position, then a home made spanner!
Wanted to use big bore tubing to help breathing on the recommendation of people on here, think the id was 12mm but don't hold me to that. Loads of pictures in the link below.
Rich
