Author: Subject: noise meter
Meeerrrk
posted on 23/9/08 at 03:27 PM Reply With Quote
noise meter
want a noise test done on my car, so i know what to expect when i arrive at the next track day (ie if they will kick me out!)
where could i get it done?
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
tomgregory2000
posted on 23/9/08 at 03:37 PM Reply With Quote
http://www.maplin.co.uk/Module.aspx?ModuleNo=46362
That should do you
Tommy
[Edited on 23/9/08 by tomgregory2000]
Guinness
posted on 23/9/08 at 03:46 PM Reply With Quote
I've got one of those Maplin sound meters sat here on my desk. (I needed one for work, honest).
If you cover the cost of registered post there and back you can borrow it for a week or so.
HTH
Mike
Meeerrrk
posted on 23/9/08 at 06:55 PM Reply With Quote
Wow, thank you
you have email
Macbeast
posted on 23/9/08 at 08:24 PM Reply With Quote
It all depends what meter they are using at the track. Note Maplin's answer to a question - it is not and cannot be calibrated- so really the measurement is meaningless.
Also note it claims to measure up to 130 dB. This must be about 60 times the sound level of a 747 taking off 100 yards away
Edit to add
The Maplin could give you a relative measurement. You would have to take a measurement on a car that you know had passed at that particular track and then compare that reading with your own car.
[Edited on 23/9/08 by Macbeast]
posted on 23/9/08 at 09:45 PM Reply With Quote
Yes!!! That's what's annoying about places like Maplins selling "noise meters". Without calibration a "noise meter" is almost useless. Good for comparative measurements but for "will this be okay for a track day" definite measurements it's no good. That's what proper dB meters cost £££££££££££.
Meeerrrk
posted on 23/9/08 at 10:15 PM Reply With Quote
oookkkaayy, so where do i get it done?!
bimbleuk
posted on 24/9/08 at 07:43 AM Reply With Quote
But a cheap noise meter. Go to a track day at the circuit you want pass at. Compare your readings to the circuits measurements on their kit. Irrelevant if their kit is calibrated you just want the reading on yours compared to their kit which is deemed acceptable!
Maybe not convenient if the circuit is several hours away! As I'm close to Castle Combe I've taken my car over on test or track days and asked for a sound reading before booking an event. It's in their interest to have cars pass the noise requirements otherwise they can potentially lose their license from complaints.
907
posted on 24/9/08 at 04:00 PM Reply With Quote
Hi.
Just to spring to the defence of Maplins....
I bought a meter from them and tested it against a car that had just passed SVA at Norwich.
It was spot on.
It 's also capable of calibration although I have never needed to.
Macbeast
posted on 24/9/08 at 05:35 PM Reply With Quote
And when you go to the track, don't forget to ask them which noise-weighting curve they're using
