Author: Subject: Custom belts?
Benzine
posted on 27/9/08 at 03:32 PM Reply With Quote
Custom belts?
I used to have a bookmark saved for a company that did custom lengths of belts (i need a long 5 tooth one, the kind that will fit on a micra alternator/crank pulley) Anyone know of where I can get one? I tried searching the site but can't for the life of me remember how I found it last time!
[Edited on 27/9/08 by Benzine]
Dusty
posted on 27/9/08 at 06:10 PM Reply With Quote
Halfords do a huge range which you may be able to select from if you measure up.
Benzine
posted on 27/9/08 at 06:53 PM Reply With Quote
I looked in halfords but the longest one they had wasn't long enough
clairetoo
posted on 27/9/08 at 07:01 PM Reply With Quote
I get mine from my local motor factor - they have a huge range , just hanging from the rafter's
How long do you need ?
[Edited on 27/9/08 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
Benzine
posted on 27/9/08 at 07:32 PM Reply With Quote
199cm or 2 meters (I have a pulley I can use to adjust so doesn't need to be bang on) Longest in my local halfords was around 180cm iirc
Edit: Plenty of belt info at the last post on this page:
http://locostbuilders.co.uk/viewthread.php?tid=69255
Danozeman
posted on 28/9/08 at 10:04 AM Reply With Quote
Im sure a proper factors like partco or somewhere must have something.
My supplier jayar have hundreds.
Dan
Benzine
posted on 28/9/08 at 10:55 AM Reply With Quote
Just tried autostop (local factor) and they've ordered me one ^___^
clairetoo
posted on 28/9/08 at 11:30 AM Reply With Quote
Two might be a good idea
Claire xx
Benzine
posted on 29/9/08 at 08:39 AM Reply With Quote
Good point
Also camskill have a huge list of 6-toothed belts (which I needed in the end, not 5 tooth as said in my first post!):
Big list of belts from about 80cm to 2.6 meters
Thought I'd post above link incase anyone searches the forum in the future
