blakep82
| posted on 2/10/08 at 03:16 PM |
clutch, which way up?
A)
or
B)
its a mondeo clutch. i don't even know how they sit in the mondeo
________________________
| posted on 2/10/08 at 03:19 PM |
B, The pipes point towards about 1 oclock when sitting in the bell housing...
[Edited on 2/10/08 by coozer]
tomgregory2000
| posted on 2/10/08 at 03:21 PM |
B so u can fully bleed it
blakep82
| posted on 2/10/08 at 03:25 PM |
balls...
need to have a think about how this will work now, coz i won't be able to get into the bellhousing to bleed it if it points up...
if it were as in pic A, then both pipes would stick out where the clutch arm would normally go, with the bleed pipe at the top, hmm...
theconrodkid
| posted on 2/10/08 at 03:41 PM |
you could have it sideways as long as the bleed nipple is on top
who cares who wins
pass the pork pies
blakep82
| posted on 2/10/08 at 04:17 PM |
hmm, i guess if i had a normal short bleed screw on it, and a 90 degree bend on the inlet, i could almost have the bleed valve at the 10 o'clock
position perhaps? would that work?
| posted on 2/10/08 at 04:34 PM |
Put a remote extension on the bleed nipple and run it through a hole on top of the bell housing.
blakep82
| posted on 2/10/08 at 04:51 PM |
is it ok to drill holes in? it cost me £170, i don't want to break it!
clairetoo
| posted on 2/10/08 at 04:59 PM |
HOW MUCH ! ! !
I bought one just like that off ebay for £45 , and broke it taking the bearing off
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
| posted on 2/10/08 at 05:06 PM |
noooooo! not the cylinder! £170 for the bellhousing! i got the cylinder MUCH cheaper than that!
clairetoo
| posted on 2/10/08 at 05:47 PM |
Oop's
I'd go with extending the bleed nipple and sticking it through a hole in the bell-housing - having the bleed nipple on the side just wont let
the air out .
Claire xx
mad4x4
| posted on 3/10/08 at 06:06 AM |
How Much I go a bellhousing for 40quid off eaby is it a special job ??
Scot's do it better in Kilts.
