Author: Subject: V6 Engine Options
Howlor
posted on 5/10/08 at 08:57 AM Reply With Quote
V6 Engine Options
What are your thoughts on the best option for a V6 mid engine? I would like something relatively small/light but with 220+hp if possible.
I was considering the 300zx twin turbo but it looks a big lump. Great power, easily tuned and I could use all the running gear/rear suspension.
What other options can you think of.
Thanks,
grazzledazzle
posted on 5/10/08 at 09:03 AM Reply With Quote
jag 3 ltr v6 - same as the mondeo st220.
prawnabie
posted on 5/10/08 at 09:37 AM Reply With Quote
Renault L7X out of a Clio?
Up to 2003 ish had 223 BHP - newer shape had 255 BHP. I think it mates up to the UN1 transaxle nicely or you could use the PK6 6 speed box it came out of the car with.
Same engine was fitted to lagunas, espaces etc but with way less power.
Shaun
mr henderson
posted on 5/10/08 at 10:41 AM Reply With Quote
For a mid engined car longitudinal engine/gearbox will give you more choices suspension-wise. Something from the Audi A4/A6/A8 range should do nicely
John
Volvorsport
posted on 5/10/08 at 04:10 PM Reply With Quote
the audi would suit better .
PRV only fit the UN1 in the earlier versions like the venutri or alpine , the clio is transverse like it is in the 406 coupe et al .
www.dbsmotorsport.co.uk
getting dirty under a bus
prawnabie
posted on 5/10/08 at 07:08 PM Reply With Quote
The UN1 can be made to fit the v6 out of the clio, there is a Renault 5 Turbo 2 with this engine/gearbox combo on retro renault.
