Pdlewis
| posted on 5/10/08 at 04:59 PM |
R1 engine question
Hey,
Being in the garage today getting my R1 5PW sorted to get it in the car and came accross somthing which i thought was odd
using the gear selector I could only click it one notch forwards and 1 back I thought i would be able to click it 7 times in each direction is this
correct?
I then took out all the friction plates and i was able to all the gears does this sound normal?
Build Photo Album
Updated 05/02/2009
r1_pete
| posted on 5/10/08 at 05:01 PM |
If you turn the output back and forth the other gears would have selected, its just a matter of getting the cogs to mesh whilst the engine isn't
turning. Normally the rotation of the engine and box allows the gears to mesh, by dismantling the clutch you allowed the input shaft to move enough to
let the cogs mesh.
[Edited on 5/10/08 by r1_pete]
Pdlewis
| posted on 5/10/08 at 05:02 PM |
cheers pete still not up to speed with this bike engine stuff
Build Photo Album
Updated 05/02/2009
nitram38
| posted on 5/10/08 at 05:13 PM |
You will go from neutral one direction into 1st gear (where it will stay), then it will need to pass through neutral in the other direction to get to
2nd, but it will spring back from 2nd (not going into neutral but looks like it) and you will then keep moving it in the same direction as 2nd to get
3rd etc (each time it springs back.
[Edited on 5/10/2008 by nitram38]
Pdlewis
| posted on 5/10/08 at 05:27 PM |
Also does anyone know what error code 11 is?
Build Photo Album
Updated 05/02/2009
CRAIGR
| posted on 5/10/08 at 06:13 PM |
http://www.r1-forum.com/forums/archive/index.php/t-206686.html
Haynes book confirms camshaft position sensor wiring or sensor
[Edited on 5/10/08 by CRAIGR]
Pdlewis
| posted on 5/10/08 at 06:43 PM |
cheers all
Build Photo Album
Updated 05/02/2009
