archspeed
| posted on 6/10/08 at 10:43 AM |
3 Inch Custom Exhaust Manufacturers - Notts / Derby Area
Could anyone advise / recommend a place in the Nottinghamshire / Derbyshire area that could manufacture a custom exhaust?
Needs to be 3 inch!! Most places I've tried seem to only do 2.5 inch as a maximum.
Thanks in advance...
Kevin
[Edited on 6/10/08 by archspeed]
MikeR
| posted on 6/10/08 at 10:47 AM |
Not quite in the area you specify but have you tried Custom Chrome in Nuneaton?
eznfrank
| posted on 6/10/08 at 11:27 AM |
You could try Martin Keenan?
archspeed
| posted on 6/10/08 at 11:43 AM |
Thanks for the suggestions,
I've not tried Custom Chrome - It is a bit far (I'm assuming I'll have to take the car to them to get it measured / built, ) but
having said that I'll keep them in mind just in case, so Thanks for the suggestion..
Martin Keenan?? That name rings a bell - Was he somthing to do with MK Sportcars?? A quick "google" tells me his place is MK Engineering
in Rotherham - So it will definatley be worth a shout!! Thanks for that.
Keep em coming - this website is great !!
eznfrank
| posted on 6/10/08 at 12:31 PM |
Yeah Martin used to own MK Sportscars before he sold it to his brothers (I think). His workshop is home based about 2-3 miles from MK's new
place. He's a decent chap who from my experience has reasonable charges and is very knowledgeable in what he does.
grazzledazzle
| posted on 6/10/08 at 03:37 PM |
Tony Law in Leeds.
Second to non in my opinion.
archspeed
| posted on 6/10/08 at 04:21 PM |
Tony Law does look good aswell!!
Wish I'd done this post last week, would have saved me no end of time !!
Thanks for the replies so far.....
Kevin
tcr
| posted on 6/10/08 at 06:46 PM |
i had mine done by a guy in bilsthorpe notts link to my zorst
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
NS Dev
| posted on 8/10/08 at 04:37 PM |
quote: Originally posted by grazzledazzle
Tony Law in Leeds.
Tony Law is in a league of his own, quality of work is excellent, most racers use his manifolds
Volvorsport
| posted on 8/10/08 at 05:08 PM |
if your building a cosworth i assume you have a turbo ?
if so , its quite easy to build your own , i did mine .
www.dbsmotorsport.co.uk
getting dirty under a bus
archspeed
| posted on 9/10/08 at 11:37 AM |
Yes it is a turbo, I do have a mate who has all the kit for "TIG" welding ( i think its TIG anyway), so he could do it for me, but I
would still need to get my hands on all the "pre bent" pipes, and a nice 3 inch Silencer so he could weld them all up for me..
that gives me another problem, as looking around, there does seem to be places that do 3 inch "pre bent" pipes ( like Demon Tweeks) but
they only do standard 90 degree type bends, not the 7 degree bend that i will need on the straight piece that runs down the side of the car into the
silencer.. Add to that - I couldn't find a supplier that makes "off the shelf" 3 inch silencers...
hope that made sense..
NS Dev
| posted on 9/10/08 at 12:25 PM |
Bends problem is easy, make em all from 90 deg bends, remember you don't have to use the whole bend!!!
Just a thin wedge from a 90 deg bend will get you a 7 deg one.
I thought Jetex made 3 inch silencers.
Failing that, milner offroad certainly sell the bits to make 3" silencers
NS Dev
| posted on 9/10/08 at 12:26 PM |
PS for the bends, use stainless dairy piping and bends, they are dirt cheap, cheaper than demon tweeks mild steel bends by miles
archspeed
| posted on 10/10/08 at 07:09 PM |
Thanks for all those who replied, its given me plenty to think about!
Kevin
