thepest
| posted on 8/10/08 at 06:55 AM |
Webber Q's
When it comes to webber carbs, is there an appropriate angle at which they should be mounted? or is Perfectly level preferred?
I have the spring washers that allow the carb to be mounted, can someone remind me how far I should be tightening the nuts? I remember I used to use a
feeler gauge.
Mr Whippy
| posted on 8/10/08 at 07:09 AM |
carbs are best kept level as they may misbehave on corners if not.
can't mind about the spring washer gap, I just tightened them up so they had a small bit of play, never that precise to use feeler gauges
Danozeman
| posted on 8/10/08 at 09:05 AM |
I was looking at these the other day and people reckon about 1mm gap on the rubber bush thing when tightened.
Dan
| posted on 8/10/08 at 11:03 AM |
The way I did it was that the difference between the two ends was just a bit more than the thickness of the spring - see RH corner.
thepest
| posted on 8/10/08 at 09:04 PM |
Thanks I'll do that! thats an easy one to remember
