Agriv8
| posted on 8/10/08 at 11:33 AM |
Primary Bore size with Cat theory ?
More a theory tread - but hey we like a discusion on here so ere we go.
V8 7 running in the 750 MC racing, all cars are going to have to be fitted with a Cat ( or 2 in the Case of the V8 ) as per MSA IIRC.
So obviously a pair of large racing cats have been ordered.
Now I am a beliver in the keeping primaries to a sensible bore size to keep the speed of the gas flow up.
But when you introduce a Cat What would an ideal bore and size be ? has anyone come across any reading / calculators to try and keep as much Power as
possible while having to force the gasses through a CAT.
Agriv8
Mr Whippy
| posted on 8/10/08 at 02:18 PM |
why do you have to force the gas through the exhaust? don't think they're all that restrictive
NS Dev
| posted on 8/10/08 at 04:34 PM |
ahhh the wonderful racing CAT that does absolutely nothing other than make life difficult!!
At full throttle the cat doesn't have time to actually convert anything at all
| posted on 8/10/08 at 05:08 PM |
Cats are restrictive by the very fact that they introduce a large increase in cross-section right at the point where the gasses are moving very
quickly. You therefore have fast pulses hitting a slow moving region of gas.
| posted on 8/10/08 at 07:48 PM |
Cats also cause restriction because viscous friction of the exhaust gases boundry layers against the walls of the very fine passages of the
cat's honeycomb matrix.
I have noticed since tintops were fitted with 3 way cat the dia of the primary pipes has increased quite a bit.
[Edited on 8/10/08 by britishtrident]
Agriv8
| posted on 9/10/08 at 06:25 AM |
I could not have put it better myself, but I can not seem to find any readding / calculations on the subject.
I thinks that the pulses are still the same as the engine is not going to change. We have now got to get that pulse through a restriction ( the CAT )
which is going to slow it down Thus cause presure buildup. So it makes sense that that presure will be less on a larger Bore than a smaller On.
There must be an optimum though ( suppose looking at the primaries of a modern v8 AUDI may release some clues ).
regards
Agriv8
