Author: Subject: Where is the ideal location of a Lambda sensor?
Mr Whippy
posted on 9/10/08 at 08:51 AM Reply With Quote
I’m fitting a LPG conversion kit to my 20 year old Bluebird, and it’s a closed loop setup utilizing a lambda sensor to control the gas mixture. The car has a carb so I need to weld in the new sensor, just not quite sure where it will work best, I suppose that it should be on the outside of the curved down pipe as would the gas stream not be most concentrated there? But how far from the exhaust, does it matter?
should soon be seeing fuel costs equivalent to about 80mpg!
Paul TigerB6
posted on 9/10/08 at 08:57 AM Reply With Quote
On my tintop its just a few inches down from the exhaust manifold on the downpipe before the catalytic converter. Exhaust gas is hotter the closer you are to the manifold isnt it.
Mr Whippy
posted on 9/10/08 at 09:05 AM Reply With Quote
Yeah but I've seen quite a variation of distances. Given that it’s not a performance car I'd expect it could be quite close, just not sure if there is an optimum temperature for it to work?
[Edited on 9/10/08 by Mr Whippy]
flak monkey
posted on 9/10/08 at 09:47 AM Reply With Quote
The closer the better with an unheated lamda sensor.
Doesnt matter too much with a heated one.
Sera
http://www.motosera.com
Mr Whippy
posted on 9/10/08 at 10:14 AM Reply With Quote
hmm cheers, apparently - "The sensors only work effectively when heated to approximately 800°C"
Oh well so much for my worries of melting it!
posted on 9/10/08 at 01:36 PM Reply With Quote
The sensor should also be mounted pointing somewhat downwards (i.e. the sensing end pointing down) rather than horizontal or upwards to prevent water getting trapped inside it.
Mr Whippy
posted on 9/10/08 at 02:23 PM Reply With Quote
oh right, never thought of that but surely it would be quite dry normally seeing where it lives?
posted on 9/10/08 at 03:32 PM Reply With Quote
[oh right, never thought of that but surely it would be quite dry normally seeing where it lives?
Exhaust gas contains a large percentage of water vapour which can condense when things cool down...
Mr Whippy
posted on 9/10/08 at 08:23 PM Reply With Quote
certainly would never have considered that, thanks
