Author: Subject: simple weber question (i hope)
24vseven
posted on 11/10/08 at 01:55 PM Reply With Quote
basicly can i use a set of 45 webber/dellortos that were origanly intended for turbo use on a pinto engine (non turbo obviously)
t16turbotone
posted on 11/10/08 at 06:03 PM Reply With Quote
basically mate you wouldnt choose twin webber 40 dcoe 's' on a turbo conversion, but they will be fine on normally asp pinto engine, will need to be jetted correctly on rolling road though
posted on 11/10/08 at 08:58 PM Reply With Quote
The 45 DHLA Dellortos made for the Lotus Esprit were specifically designed for blow through turbo use. They could be used for a normally aspirated application as long as you can find a rolling road that is familiar enough with them to re-jet them correctly.
prawnabie
posted on 11/10/08 at 10:02 PM Reply With Quote
Yeah i second that. Im pretty sure apart from the jetting (which you will obv. change anyway) the seals are different as pressures inside the carbs are different
Shaun
