Author: Subject: fuel sender
dunk3
posted on 13/10/08 at 10:15 AM Reply With Quote
fuel sender
hi all how do you fit a fuel sender to a standard alloy mk fuel tank like this one. and wheres the best place to get a fuel sender from. cheers Rescued attachment mk fuel tank.jpg
stuart_g
posted on 13/10/08 at 10:17 AM Reply With Quote
Fuel sender needs to be matched to the gauge ideally. The Racetec gauges and sender are very good. As far as fixing to the tank I used rivnuts with no problems.
jollygreengiant
posted on 13/10/08 at 10:42 AM Reply With Quote
I used the sender unit from my donor (granada) as I am using the instrument panel as well. Just cut the mount out of the tank and screwed it onto the tank using rivnuts and the seal (cork) between plate and tank came from a spare gasket from behind the nose of a type 9 gearbox. Photos are in archive.
Plate mounted
Plate mounted
Sender unit mounting plate
Fuel sender unit in situ
[Edited on 13/10/08 by jollygreengiant]
Benzine
posted on 13/10/08 at 10:49 AM Reply With Quote
I'd also recommend rivnuts. I used rivets first time round and my sender wasn't quite set up right and I didn't want to drill out the rivets and leave swarf in the tank. Now that I've re-built my MK I've used rivnuts and I've already had it out again once to fine tune it Mine is bang in the middle of the tank
DavidW
posted on 13/10/08 at 12:01 PM Reply With Quote
I put my sender in the middle of the top face, secured with rivnuts.
Seems to work fine.
