FastBarney
| posted on 13/10/08 at 04:10 PM |
webers for silver top ==> black top
Hey
Can i place webers and manifold that are set for a 2l silvertop on an 2l blacktop?
or do they need to be re-jetted?
If i change the rampipes to smaller one's
Do i need to re-jet tehe carbs then?
thanks
cheers Barney
Jenko
| posted on 13/10/08 at 04:33 PM |
Problem is...No two engines are the same..I would say they would be close, but to get carbs optimised, you need to rolling road them....any change in
either inlet length or exhaust system COULD shange the jetting requirements.....
That said, you will be in the ball park if you previous jets were set up on a RR. Best thing to do is try it.......
stevebubs
| posted on 13/10/08 at 05:48 PM |
be close enough to get you running. Would recommend a decent rolling road once fitted to check them properly though...
