Author: Subject: MK - Pinto Engine Mounts
perksy
posted on 13/10/08 at 05:46 PM Reply With Quote
Trying to help a Mate out who has a Pinto Powered MK
He needs some Harder Engine mounts because the Engine is 'moving' too much and i wondered what other owners did to stop this ?
Also where they got their uprated engine mounts/Material from ?
Perksy
graememk
posted on 13/10/08 at 05:48 PM Reply With Quote
they fitted bike engines
The Baron
posted on 13/10/08 at 06:50 PM Reply With Quote
I have seen pinto users add an additional engine mounting from the chassis top rail to control the roll of the engine.
Mark Allanson
posted on 13/10/08 at 06:51 PM Reply With Quote
I used LR mounts, in a book chassis, but my pinto has less than a total of 5mm movement
jacko
posted on 13/10/08 at 07:04 PM Reply With Quote
This is how i stoped mine moving have a look in my photos
Jacko
[img][/img]
matt_claydon
posted on 13/10/08 at 08:21 PM Reply With Quote
Land rover mounts are what you need, same thickness but much much stiffer than the silly Fiesta gearbox mounts MK supply. With the pinto on the MK mounts I could grab the rocker and shake the engine around easily, with the LR mounts it was nice and firm.
eg LR mounts
You can get them a fair bit cheaper than that though.
Better solution of course would be if MK designed the mounts properly and didn't have the two rubbers in the same plane.
[Edited on 13/10/08 by matt_claydon]
Mr Whippy
posted on 14/10/08 at 08:01 AM Reply With Quote
Jacko
engine mounting
engine mounting
that’s pretty smart
