Author: Subject: Rich or lean stumble?
thepest
posted on 15/10/08 at 07:53 PM Reply With Quote
Been tuning a crossflow last weekend. Sorted now but with alot of trial and error.
Basically there was a flat spot between 2000-3000RPM or so.
As the title says, is there any way of identifying what the hesitation on the engine could be with regard to fueling?
posted on 15/10/08 at 08:23 PM Reply With Quote
What carbs have you got on the engine?
What ignition system?
(It helps to know these things... )
Originally I got my x-flow (with a Weber DGV carb) sorted at a rolling road. When I fitted bike carbs I sorted it with an air-fuel meter - but I had to weld a boss into my exhaust system so that I could use it.
maartenromijn
posted on 15/10/08 at 09:05 PM Reply With Quote
Normally a lean engine has yellow spark plugs, and a rich engine has black spark plugs.
But it could maybe also be: length of the inlet or exhaust manifold. I have got no idea how you can check this.
Maybe you should get friends with the local tuning company...
BLOG: http://thunderroad-super7.blogspot.com/
thepest
posted on 15/10/08 at 09:12 PM Reply With Quote
ops yea good point, running on DCOE's and running megajolt.
Looks like I'll purchase a JAW or similar to help me out, anyone know of any other unit that is "locost" ?
Jenko
posted on 16/10/08 at 03:57 PM Reply With Quote
I have a Techedge which I find good, although only slightly cheaper than Innovate.....But treak it like a tool, once you buy one, you can keep it forever.....IMHO worth every penny....
thepest
posted on 17/10/08 at 05:56 AM Reply With Quote
Thanks I think I'll get one!
