Author: Subject: bhp?
paul_mcq
posted on 13/1/04 at 04:22 PM Reply With Quote
bhp?
watsa the highest u can't get out of the 2lr pinto?
Alan B
posted on 13/1/04 at 04:35 PM Reply With Quote
These guys would know....I bet it's huge...and expensive....I think they are probably the best pinto tuners in the world...
http://www.esslingerracing.com/index.htm
stephen_gusterson
posted on 13/1/04 at 04:38 PM Reply With Quote
a billion horsepower
absolutely can't get that
atb
steve
blueshift
posted on 13/1/04 at 04:49 PM Reply With Quote
no wait, 10 billion horsepower is higher and you can't get that either.
AHA!
macspeedy
posted on 13/1/04 at 05:43 PM Reply With Quote
on a reasonable budget 160-180 using balanced parts and ported a head and twin 45's
david walker
posted on 13/1/04 at 07:04 PM Reply With Quote
Serious question - What's the definition of reasonable?
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
dblissett
posted on 13/1/04 at 08:27 PM Reply With Quote
bhp
i think you should limit it to about 160bhp
you can get higher but it may be more cost effective to look at zetecs above that
as the pinto needs alot of money spending on it to get above 160
also try david visards pinto tuning book
its very good
cheers dave
Julian B
posted on 14/1/04 at 09:52 AM Reply With Quote
Don’t forget about driveability
If the engine needs to be "on the cam" all the time it will drive like a dog in town, fantastic on the track but a dog in town. If you want very hi bhp from a smallish engine and drivability, you will need to think about clever fuel injection and intercooled turbo charging. Ka ching ££££££
DaveFJ
posted on 14/1/04 at 02:25 PM Reply With Quote
well the cosworth engine is technically kinda like a pinto ish... err
well its a pinto block with a cossie head (more or less)
my intentions are for a mildy sorted pinto to start with and then swap at a later date for a cosworth engine - the same block should mean an 'easy' swap
to get an idea of tuning have a look at Giles Cooper's site - he has a fair bit of info on there
http://www.gilescooper.co.uk/
Dave
Dave
garage19
posted on 14/1/04 at 03:03 PM Reply With Quote
At the recent Suffolk Locost meet i spoke with another list member (he will remain un-named uness identifys himself*) who used to work for Holbay. He said when Ford were putting out the tender for developing a turbo version of the pinto, Holbay took a stock transit pinto cos they have a lower comp ratio, bolted a turbo on and ran 220bhp almost straight away!
Would be interested to know what sort of fueling they used.
* your only clue is he has a boat engine in his car!
DaveFJ
posted on 14/1/04 at 03:59 PM Reply With Quote
Dave
James
posted on 14/1/04 at 04:44 PM Reply With Quote
Garage19,
Interesting...
Perhaps your anonymous friend would be willing to give us a few more tidbits!
James
theconrodkid
posted on 14/1/04 at 04:55 PM Reply With Quote
gives the word "prop" a whole new meaning,is it a volvo penta by any chance?
who cares who wins
pass the pork pies
timf
posted on 15/1/04 at 09:02 AM Reply With Quote
it's not a boat engine its a truck engine.
btw i worked for ford. holbay were asked what they had suitable.
ford did the turbo lc transit using the sierra injection manifolding and a custom ecu for the fueling the first dyno run produced 200 bhp at the end of the testing the bhp was at around 450 bhp but to get this reliably a 205 block and a set of forged low comp pistons, steel rods and crank were used also the heads were 'o'ringed to the block.
the biggest problem we has was ford wanted a 'big' name for the flagship sierra and cosworth got the contract.
Tim
mackie
posted on 15/1/04 at 09:30 AM Reply With Quote
They do use that engine in boats too, albeit adapted for marine use I'd imagine. Had a go in a Mastercraft waterski boat with a 5.7l mercury (I think) V8 in it making around 290hp, went quite nice!
garage19
posted on 15/1/04 at 11:29 AM Reply With Quote
Tim
They used it in school buses and combine harvesters as well, didn't they?
DaveFJ
posted on 15/1/04 at 11:33 AM Reply With Quote
Well he is from Suffolk....
A Locost harvester ???
Dave
Dave
greggors84
posted on 15/1/04 at 12:36 PM Reply With Quote
My uncle had a water ski boat, a ski nautique (a type of master craft) im pretty sure it had the old mustang engine in it the 4.7l V8 (289cu) or it might have been a 5.7l V8. It couldnt run in the sea as the salt water would wreck the cooling system as it was pumped round then dumped out to save a rad.
Their not cheap engine donors though, he sold a ten year old boat for around £8k. I was always hoping he would scrap it one day and i could have the engine
[Edited on 15/1/04 by greggors84]
Chris
The Magnificent 7!
mackie
posted on 15/1/04 at 01:01 PM Reply With Quote
This mastercraft was running in salt water, no idea what cooling system it had though. It did however have straight-through exhaust pipes that exit underwater so if you reversed too fast it conked out!
