Jesus-Ninja
| posted on 18/10/08 at 01:08 PM |
what materials for engine moutns and where to get it?
As per the title really I need to make up engine mounts for my Saab lump, adn whilst I can get the steel for them, where can I get the
rubber/poly/nylon/whatever-else from?
zilspeed
| posted on 18/10/08 at 01:09 PM |
Ooohhh, Saab Lump
Which gearbox ?
Jesus-Ninja
| posted on 18/10/08 at 01:14 PM |
quote: Originally posted by zilspeed
Ooohhh, Saab Lump
Which gearbox ?
Saab
transverse across the back axle
tomprescott
| posted on 18/10/08 at 02:33 PM |
Don't know if they'd be anyuse for you but you can pick up engine mounts for escorts and capris on ebay, basically a really stiff rubber
bush, hope it helps. Tom
stevebubs
| posted on 18/10/08 at 03:20 PM |
Why not get the mounts for the car it came out of and then build a cradle that mates it to your chassis?
zilspeed
| posted on 18/10/08 at 03:36 PM |
Ooohhh, Saab Lump
Which gearbox ?
Saab
Which sort of makes sense when you actually think about it
| posted on 18/10/08 at 04:09 PM |
Land Rover engine and Fiesta gearbox mounts are easy to get hold of and cheap. They are handy having a bolt sticking out of each side as well.
Cheffy
| posted on 18/10/08 at 04:11 PM |
As stevebubs said.
That's what I did for my V8. Used the SD1 engine mounts (chopped by about 40mm to bring the mounting rubbers closer in to the engine) then used
the SD1 rubbers mounted in cradles that I fabricated myself.
  V8 engine mounts
Hope that helps,
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
Jesus-Ninja
| posted on 19/10/08 at 09:25 AM |
Right, I've made my decision
Bought a bar of Delrin, which I'l use to tmake my mounts with. It's pretty hard stuff, but should hold things nice and solid
Syd Bridge
| posted on 19/10/08 at 11:39 AM |
I wouldn't use Delrin for engine mounts, you may as well hard bolt it direct to the chassis.
Go for one of the options mentioned above.
SYd.
Jesus-Ninja
| posted on 19/10/08 at 01:21 PM |
SYd.
The engine mounts in the S14 (see avatar) were made of this. It's a good opportunity, I have decided, to make the mounts up using delrin to get
the engine mounted. If NVH is too severe, I'll make some out of a softer material, like poly, but poly is flippin expensive! Especially to try
fittings and get it wrong.
Syd Bridge
| posted on 19/10/08 at 05:59 PM |
Delrin is very hard, and extremely non compliant. A man would be a fool to use it for engine mounts. (I nearly said 'moron', but Fozzie
would give me a tickin off for that. )
If you want to use Delrin, why not save money and use ali or brass, or steel even!They would give the same result.
Heck, why not just hard bolt the sucker and save a lot of work.
Do yourself a favour, and buy some Landy mounts for a few £'s each, and save your engine and chassis from a lot of unnecessary torture.
Syd.
