Author: Subject: dash exempt areas
A1
posted on 18/10/08 at 03:31 PM Reply With Quote
dash exempt areas
are the areas round the steering wheel mentioned in the sva manual allowed to be long with sharp (ish) edges?
i just want to be 100% sure so i dont fail
fesycresy
posted on 18/10/08 at 03:34 PM Reply With Quote
127mm from the edge of the wheel rings a bell.
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 18/10/08 at 03:39 PM Reply With Quote
127mm is correct either side f wheel so find a nice big standard wheel to get the maximum exemption area
A1
posted on 19/10/08 at 12:18 PM Reply With Quote
cheers, i thought it was that... ive got an omp wheel...cant fit in otherwise!
Rallye_Mark
posted on 19/10/08 at 05:48 PM Reply With Quote
Hope this helps, got it off the forum a while ago. Rescued attachment Exem.jpg
bikenuts
posted on 6/11/08 at 05:26 PM Reply With Quote
Can someone confirm that I'm reading the rules correctly; areas A,B and C are all exempt? Also how exempt are they? ie how "sharp" can something in the exempt area be? is there a limit or anything goes?
