sonic
| posted on 19/10/08 at 03:10 PM |
5JJ R1 engine help
Hi All
Could anybody help me with some info please
R1 5JJ Carbed engine
1/ does anybody have a picture of where the infeed is for the fuel pipe.
also mine has a black plastic box under the carbs which say's P P on it,i have a pipe which comes out of it that when you turn the engine over
blows fuel out and i cannot see anywere it connects too.?
2/ the sump pan on the same engine has all the attatching bolts around the outside and all so two recessed hole on the flat of the pan underneath,one
has a attatching bolt thats goes into it the other is to small for a bolt to go in, when filling with oil it leaks very slightly out of this hole and
i don't know what is ment to be in it,any ideas
adithorp
| posted on 19/10/08 at 03:36 PM |
The hole in the sump is a leak off from the water pump should its seal go. As the pump's internal it'd leak water into the sump otherwise.
There's a small pipe from it to the hole you can see and has an O ring sealing it.
Sorry don't know about the carbs.
adrian
http://jpsc.org.uk/forum/
sonic
| posted on 19/10/08 at 03:53 PM |
Hi Mine has oil coming out of it
adithorp
| posted on 19/10/08 at 04:04 PM |
That'd be the O ring that seals the outer tube and the sump.
adrian
sonic
| posted on 19/10/08 at 04:48 PM |
Thanks for that i will have to drain it and get an O ring.
