sweston
| posted on 15/1/04 at 08:58 PM |
Throtle assembly Xflow Weber Down Drought
Any one got a picture of a throtle assembly on a weber down drought on a xflow.
Currently I have a assembly on the rocker cover. Hate it as have to disasemble everything to get the cover off.
Have seen photo's that look like people rig something off the inlet manifold where the carb is bolted down ?
GasGasGas
| posted on 15/1/04 at 10:26 PM |
cortina's used a rocker cover mounted throttle linkage, and escorts used a manifold mounted linkage
best option is to source an escort gt or e type manifold and linkage
or mimic the sheet metal in the attached picture
SeaBass
| posted on 16/1/04 at 08:46 AM |
I had the same problem. The manifold I sourced didn't have the two bolt holes for the linkage plate. I fabricated a bracket using parts from the
Motorcraft carb bracket to use... Like this
There are other pics on my website on this page...
sweston
| posted on 18/1/04 at 08:52 AM |
Thanks for the pics guy's.
See how my metal work goes.
