paul_mcq
| posted on 18/1/04 at 02:34 PM |
carb problems
can u fit a set of motor bike carbs to a 3.0 v6 ford engine???
200mph
| posted on 18/1/04 at 05:51 PM |
motorbike carbs will come from a four cylinder engine. a V6 has, erm, well 6 cylinders.
you do the math
[Edited on 18/1/04 by 9904169]
Jon Ison
| posted on 18/1/04 at 06:11 PM |
rv8 as 8 clys, 2 carbs
ford v6 as 6 clys 1 carb.....could go on
bit o work but 3 banks of 3, ditch one maybe? or all 4 into one chamber ?
some on here have fitted bike carbs to 4cly car engines they well tell you how well they worked,
years ago it was common to run 2x45's on 2 port mini heads only using one barrel from each, theory was to get a straight run into ports, things
have moved on a bit since then, but using 3 of the 4 chokes from bike carbs would look the bizz either side a v6 motor, just a few ideas that may or
may not work.
better idea, fit the bike carbs with a bike engine under em n ditch the V6
greggors84
| posted on 18/1/04 at 07:02 PM |
Whats the advantage of using bike carbs over car carbs, if any?
Chris
The Magnificent 7!
