So you have a chassis and the wheelbase is 3cm too long for the bodywork you want to use. The front-end is ok, so any mods are going to happen at the
rear.
It's a full bodied car, so lengthening the bodywork is out.
You also can't shift the rear suspension mounts.
That leaves changing the rear wishbone geometry to reduce the wheelbase. I know the square route of bugger all about geo, so is this a workeable
solution, or is it a sure-fire way of completely screwing-up the rear suspension?
Well within the tolerance of the cv joints, the pivot points remain the same.
Analogy time
Look at locost fronts, even length, then look at some other types with the front bone at right angles and the rear 45 degrees.
Only concern then is the shock will now lean a bit, can you modify the brackets to put back in line?
Originally posted by scootz... is this a workeable solution?
Thanks for the replies guys!
Hi Scot,
What sort of car is it, to start with?
You might not be able to change the body length, but cutting the arches, moving them, and glassing/filling in between, then fairing it up and painting
would save a lot of headaches and maybe cause a few more?
Nev.
