Does anyone understand the DVLA policy for Date of first Registration?
I recently passed my IVA and applied for registration with the DVLA. The car uses some components from a 1992 Ford Sierra and the V5 for the donor
car was provided with the application.
I was awarded an age related 'K' reg number which is what I wanted and expected.
However, the Date of First Registration is 01 08 2023.
On the front of the new V5 says 'Rebuilt - assembled from parts some or all of which were not new'
I questioned the Date of first Registration with the the DVLA kitcar department who say 'The date of registration is when the new vehicle is
registered and should not be taken from the date of registration of the donor vehicle.'
This is inconsistent with a lot of registered kitcars already on the road.
It seems illogical to have an age related plate and a Date of first registration of 2023?
It's not a problem for me, just trying to understand their policy and logic?
What have others experienced recently?
P.S. It comes up as ULEZ compliant
[Edited on 20/9/23 by pfedwards]
Your car first exist until you registered it. The donor was scrapped at that time. That was its first registration and therefore that's the date of first registration.
Yes - same as my recent Q-plate and as-expected.
Until fairly recently (during IVA) you got a date 1st registered, which would be that of the donor & a separate date of 1st reg in UK, or similar
wording to that - I take it they've dropped the 2nd date?
I can understand why they might do that as it could be confusing, my Furores used to get a date 1st reg like 1987 or 89, whatever & a date 1st reg
in uk of 2012. 2017 or whenever submitted
Don't forget though, that vehicles get 3 years of MOT exemption from the vehicles first year of registry, if you had a pre dated first registry,
you'd loose the exemption.
Jason
I recently passed my IVA and applied for registration with the DVLA. The car uses some components from a 1992 Ford Sierra and the V5 for the donor car was provided with the application.
I questioned the Date of first Registration with the the DVLA kitcar department who say 'The date of registration is when the new vehicle is registered and should not be taken from the date of registration of the donor vehicle.'
P.S. It comes up as ULEZ compliant![]()
Mine was registered in 2018 with parts which gave a 'S' plate. I don't see any problem,the plate is age related so helps MOT testers with emisions etc and it is a newly created car for MOT issues, ie 3 years before needed. After all its been through IVA which is much more stringent than a normal MOT. OP seems the same
Originally posted by russbost
Until fairly recently (during IVA) you got a date 1st registered, which would be that of the donor & a separate date of 1st reg in UK, or similar wording to that - I take it they've dropped the 2nd date?
I can understand why they might do that as it could be confusing, my Furores used to get a date 1st reg like 1987 or 89, whatever & a date 1st reg in uk of 2012. 2017 or whenever submitted
Originally posted by Deckman001
Don't forget though, that vehicles get 3 years of MOT exemption from the vehicles first year of registry, if you had a pre dated first registry, you'd loose the exemption.
Jason
Although the V5 gives a first registration date of 2023 if you check the DVLA tax/MOT status site it will probably show date of first registration as
2023 BUT date of manufacture as 1992. Mine certainly does.
The next bit doesn't relate to the OP but might be useful to others...
The date of manufacture is the one used for historic tax purposes ie. if the maufacture date is more than 40 years it is eligble for histiric tax. In
my case a 1978 donor so is eligble - DVLA atcually wrote to me and suggested it!
Of course that does not necessarily mean it is exempt from MOT because as well as being built or registered 40+ years ago it must have had no
'substantial changes' in the last 30+ years ie. as a kit car 30+ years after it was registered as such.
In my case it won't be eligble to be MOT exempt until 2030 as it was registered as a kit car in 2000.
Thats my understanding from recent experience anyway.....
