diff change in live axle
joolsmi16 - 1/8/11 at 08:17 PM
Hi all, as title has anyone any hint / tips or online manual for replacing a diff in a live/english axle??
Have been told it can been done without removing from car and is very simple!!(fatal words)
Joolsvery simple
deltron63 - 1/8/11 at 08:24 PM
really easy. Pull out the drive shafts with a puller. remove prop. undo the diff bolts and pull out the diff. job done.
joolsmi16 - 1/8/11 at 08:55 PM
Can it be done on the car by rotating the axle or is it best to remove the axle?
Anywhere I can find the torque setting for the prop and diff bolts?
deltron63 - 1/8/11 at 09:42 PM
The axle can be left on the car to change the diff
Dangle_kt - 1/8/11 at 10:09 PM
its straightforward except...lifting the diff into place - some of the clearance isn't great and it flipping heavy to have lying on your back, away from your body (if you dropped it on your face it would make a REAL mess) trying to get 10+ studs to line up...
get a mate round.
joolsmi16 - 1/8/11 at 10:31 PM
great.. will let you know how I get on over the weekend..
Jools
