Hi all,
I have a Quaife PowerTec axle unit taken from my Suzuki Hayabusa powered kit car, these are originally from the Radical SR3.
These PowerTec Axles are fitted to a Radical SR3 and eliminate the need for a chain drive, and have built in reduction gears that you can alter and
also a LSD differential.
Also an integral reverse.
This one is in nice condition, always had new Silkolene Syntran oil.
C/w set of spare reduction ratios (A-3R1-21 11/01 (cost £250);
C/w new push pull cable.
Would also Swap / Part-ex for a Hewland Mk9 with Mk5 internals or 45mm Jenvey Throttle bodies or MBE with / without cash either way.
Thanks.
[Edited on 17/6/11 by MydT9]
[Edited on 18/6/11 by MydT9]
Now SOLD.
Need to post reply to be able to ad a new topic
