Sentri Van Safe
Krismc - 14/11/11 at 08:18 PM
Ive got this Van safe...
http://www.safesecurityservices.co.uk/sentri-van-box-p-472.html
Had it around 18 months, rarely use it
SENTRI series of van boxes offer the highest level of Auto storage security.
Customer maybe required to offload unit.
• Patented Sentri XLOCK 4 point locking system operated by one lock
• Boxes numbered foroptional replacement key service.
• 1.6mm and 2mm sheet steel construction.
• Anti jemmy bars all round.
• Full length concealed piano hinge.
• Twin hydraulic lid arms.
• Drop down handles.
• Black powder coat finish as standard.
• Fixing holes as standard.
• 3 year manufacturers warranty for defective parts.
Just under 1meter long and 450 T x 450 W (see web site for exact measurements)
you can bolt it down, its got big bolts all around that wont let any one get in even with a crowbar.
I emptied the safe the other day and there is a slight problem i left it in the open position and drove home from shefield to newcastle, like a dingbat , and the weld on the hinge snapped off.
Nothing is bent or damaged apart from either a) it needs welding along the current hinge or b) i can drill and bolt the hinge along its lenght which will do the same job.
I could probably get it welded if i ask around locally if someone want s me to do it, and im only selling as im loosing my work van and its got 2 safes in and one is going in the garage (small one) and im selling this bigger one.
it was £185 new.
Bargin at £60 as is. collection only unless some one can get a courier??
I can drop off around newcastle area if required.
Pictures uploading, ill get them on soon as i can.
Guinness - 14/11/11 at 08:37 PM
Kris
If you can get it welded back up I'll take it mate if it's still available.
I've sent u a u2u!
Mike
Krismc - 14/11/11 at 08:48 PM
Of course mate, ill ask about and see what i can do.
pics here.....
Krismc - 18/11/11 at 02:49 PM
BTTT
