Flatshift Sensor as used by Flatshifter http://www.flatshifter.com
This is just the Flatshift Sensor c/w a Superseal loom connector. This was fitted to my old Busa powered kit car with a Power Commander and worked a
treat, factory set for a 60milli/sec (but is adjustable) electric cut for a smooth up-shift. The sensor activates when it is compressed or when your
gear connecting rod pushes the sensor. Will post within uk for £95
Also, alloy petrol swirl pot as used in my old Busa fuel injection set-up. This swirl pot measures 100m diam x 140mm high with a square mounting base
of 130mm x 95mm with 6mm diam holes. I am also including 4 used JIC -6 alloy threaded aeroquip hose ends for super tight seals. Posted within Uk for
£55
Happy to answer any questions, PM or Text on 07866 465125
I can provide the pin location details of how to connect the flat shifter cable to a Power Commander 3.
Still available before they find their way to a famouse auction site ....
Hi there, interested in the flatshift sensor if still available?
u2u sent
Provisionally sold to me
Hello did you sell the sensor? I've been waiting to pay you but it looks like you may have sold it to someone else????
Flatshifter and Alloy Tank Now SOLD.
I was winning on eBay and struck a deal for £75 but sold it behind my back not read my u2u messages thanks!!!!!!
Unfortunately it wasnt quite like that, I had to remove the ebay ad as it was incorrect, my apologies. You had all my contact details and could even have even phoned or Text me yet you relied on a U2U which as you know, if you dont LOG IN you don't see the notification.
What was wrong with your eBay ad? And I've replied to your u2u messages when I could if you look at your u2u messages you will find one from me which YOU havent read. so therefore it was down to you to reply to me I didn't have any payment details for you if I did I would have paid you there and then.
