HI all, sorted the last problem of the engine not running on tick over due to a faulty AFM the car now runs on tickover but today after 5minutes
engine cutout back fired through the K&N type air filter (smoke) then wouldnt start after that?
I did'nt do the conversion and Iam starting to regret that as I dont know where to look, the only thing I can remember the garage saying is that
they didnt connect the lamba sensor because the engine will run will out.
I need to get the car running as summers coming!!!!
Any ideas will be great, also does anyone know where to get a steel bonnet for a 7
Jools
How about this bonnet
Westfield Alloy Bonnet (louvered) for (SEi) | eBay UK
Sorry it's not much help but I'd say there's more than one problem here.
My C20XE (Never had a lambda with the Dizzy on the cam) will startup and run fine without the Airflow meter even connecting, I left it unplugged by
accident once and other than having a hyper sensitive throttle it drove ok.
The garage saying they didn't connect the Lambda sounds very dodgy.. If it's running a standard ECU it really should have it and will be
expecting signals from it surely.
Are you running standard injection set up? If si is it 2.5 motronic (dizzy) or 2.8 motronic (dispac)
C20XE will run withou the lambda connected, but will run lean, so not wise to do for ver long. (My MoT man did it for me to get me thru my
emmisions)
If you do fit/replace it, dont get a cheap generic one, get a proper bosh one.
I dont see how the AFM would have been doing much to the idle, thats usually down to the idle valve, which is a fairly common fault with the bosch
idle valves, but fortunately, they are farily common to vauxhalls, volvos, saabs and more.
The smoke from the filter soounds odd, was it a on off puff of smoke or does it every time you try to start? Are all the breathers/vacuum pipes clean?
the engine is a dizzy type, the engine was running very rich "black plugs" changed AFM ran ok for a short drive, now runs for a few minutes
then cuts out.
I welding in the lambda and connected over the weekend and no change, what other sensors can I look at?
Jools
"I Welding in the Llambda..."
Sorry do you mean you soldered in one of the universal type Llambda sensors ?
a Dodgy TPS or Coolant Temperature Sensor would also cause over fuelling
The lambda sensor that come with the engine was never fitted by the guy who did the conversion so I cut the exhaust and welding the threaded boss to
fit the standard lambda sensor.
Just been reading about the idle control value, I only have one pipe/hose going to the value should there be two and if so were do the hoses go
to??
The engine at the moment is not running rich, but will start replacing sensors soon...
Jools
