Blacktop Zetec Inlet Manifolds
pekwah1 - 23/12/13 at 11:02 PM
Hi Guys,
Just a quicky, i'm about to put a 2.0 blacktop into my Striker using stock ignition and ECU.
What inlet manifolds would bolt straight onto this engine which might be a bit smaller than the 2.0 massive plastic plenum?
madteg - 23/12/13 at 11:29 PM
You can get a 1.8 silver top inlet manifold of a EFI engine, this has a 30mm thick conversion plate with injectors in it. Then it is easier to make your own, just have to make the plenum. Using the original throttle body, Also if you want to fit bigger injectors in the future. Just use side fed injectors.
I am using 460cc injectors of a subaru sti that i brought for £6o of the Bay. There is some pics in my archive. Kev.
[Edited on 24/12/13 by madteg]
Scuzzle - 24/12/13 at 04:22 AM
The 1.6 is very restrictive with a small bore, the 1.8 115 ps is better but the 130ps HO manifold on the RS1800 Fiesta or Escort GTi is the best of metal inlets.
Like you say the plastic ones are big and bulky the metal ones are better if you have space restrictions.
madteg - 24/12/13 at 07:24 AM
Sorry my mistake it is the 1800.
http://www.locostbuilders.co.uk/gallery/locost%20turbo.JPG
Barkalarr - 24/12/13 at 08:09 AM
I think mine is a griffin inlet plenum on my blacktop in the Indy.
Will take some pics later
big_wasa - 24/12/13 at 06:54 PM
You could do a lot worse than see if Daveb666 still has my old manifold, It was for sale when he changed over to throttle bodies.
JeffJeffers - 24/12/13 at 07:56 PM
I have a manifold that will work. I'll get a couple of pictures taken if you might be interested.
