Any of you chaps got a source for 4AGE big end bearings? Other that Toyota.
A local engine machineist or motor factor should do them.
bpj services near hereford stock all things 4age, not sure about price though! www.bpjservices.co.uk, also could try fensport.
Toyota bearings would be ideal, as they are coded to fit the crank and the block with a perfect fit.
"Jobber" bearings will work fine, just not as precise.
Check your local auto parts store.
I bought Toyota rod bearings ($20 cdn each) and main bearings ($25 cdn each), whereas I could buy a fill set of jobber bearings for $75 cdn (if I
remember correctly).
Toyota parts are pricey.
G
Cheers chaps,
MrT's prices are generally issued with KY jelly and a request to bend over.
Will try BPJ.
Chris
www.tedcomponents.com/4ag.htm
$650 Canadian
