kurt
posted on 22/3/09 at 04:14 PM |
Help! Fireblade immobilised.
I have a firebade which I bought off eBay and have been fixing up over the winter. I have discovered it has an aftermarket immobiliser fitted.
I've just refitted the battery and the immobiliser beeps when I turn the ignition on and the bke won't turn over. It seems like the
immobilise has done it's job and immobilised the bike, but how do I reset it? There is no makers name, just a tatty sticker which I can just
make out the letters 'mobil'.
Any ideas anyone?
mr henderson
posted on 22/3/09 at 04:39 PM |
Not exactly overwhelming us with info there, are you?
Most immobilisers need some kind of key, usually electronic in nature, to deactivate them. If you don't have the key then you are going to have
to remove the unit and rewire it back to standard
John
kurt
posted on 22/3/09 at 05:29 PM |
Thanks for the reply. I've found out that it's a Datatool Duo, which as you say has a key, which I don't have. So, it's
coming out. Thanks anyway.
Cheers, Kurt
