wrigglypig
posted on 5/9/09 at 08:35 PM |
problems
following me fitting the zzr1100 carbs to my 2L pinto last week I opened the jets up to 1.5 mmand it ran after a fashion. When I fitted the universal
fuel pump, which is for carbed cars only. The pumped ticked for 20 secs or so till it filled everything up, then I started it and as I say it ran
after a fashion. When I came to it 2 days later I turned it on to fill it all up and it just kept on ticking away until I got bored. There is loads of
fuel in the tank, new filter fitted the right way round, the pump is made by FAI automotive PLC it is for carbed vehicles only, can be used in any
orientation its an HB13B rated at 1.5 lt/min at 2-3 psi. I have changed the pump for another one the same but its no different any ideas welcome.
Kev
philhoward
posted on 5/9/09 at 08:43 PM |
Is it pulling in air from a loose connection or split/hole in the hose.
I had the same problem and it was a loose jubliee clip
iscmatt
posted on 5/9/09 at 08:45 PM |
try a bike fuel pump? I think thats what most do with bike carbs. Its what i have done with my 2ltr pinto running zzr1100 carbs, i use a fuel pump
from a kawasaki zzr1100, with no problems for 3000 miles
myke pocock
posted on 5/9/09 at 08:48 PM |
I have a Facet pump and Filter King fitted on my bike carbed Skoda trials engine. Works for me.
wrigglypig
posted on 5/9/09 at 08:53 PM |
I cant see it is getting air in anywhere, and if I take the outlet pipe off the carbs it squirts fuel everywhere, if I put my thumb over the end it
still keeps ticking away and does not seem to register that ther is resistance there i.e. the outlet is blocked. Is there anyone with a pump they
could let me try to eliminate the problem please? I have it booked in with Boggs on Tuesday
omega0684
posted on 5/9/09 at 08:55 PM |
i ran facet red top and filter king on when i ran carbs and had no problems.
Guinness
posted on 5/9/09 at 09:45 PM |
I've got a spare ZZR pump, but I'm not down south until later next week.
I could see if there is a Post Office open tomorrow,
or get it on a before 9.00 am delivery on Tuesday morning, if I can get it in the post on Monday?
Mike
wrigglypig
posted on 5/9/09 at 09:57 PM |
u have u2u
wrigglypig
posted on 5/9/09 at 10:02 PM |
would a sticking float cause the problem or would it overflow? cant say I have seen an oveflow on the carbs??
