Author: Subject: live axle
joolsmi16
posted on 2/6/10 at 07:37 PM Reply With Quote
live axle
Hi all, what's the easiest way to find out the diff ratio of my live axle??
May have a change of plan on my engine conversion, just bought a c20xe now thing of a bec as I have experience of bike engines.
Issue I have is that my car is about 650kg with a crossflow and type 9, so my bec will weigh around 550kg!! would this be too heavy and still to my original cec??
Julian
Madinventions
posted on 2/6/10 at 07:57 PM Reply With Quote
Can you not just count the number of turns of the input shaft for 1 revolution of the output shaft?
Ed.
View my band website:
http://www.shadowlight.org.uk
joolsmi16
posted on 2/6/10 at 08:05 PM Reply With Quote
live axle
true that will give me a rough idea be better if I knew the different ratios of a standard the live axle..so I can gauge it better.
Tiger Super Six
posted on 2/6/10 at 08:24 PM Reply With Quote
There's normally a metal tag on the back that says the number I think, there was on mine.
Mark
Tiger Avon
posted on 2/6/10 at 09:00 PM Reply With Quote
550kg with a bike engine is fine!! Not sure it'd make that much difference though.
Bike engine is 60kg (ish?).
Is a Crossflow and type 9 really 160kg?
posted on 3/6/10 at 10:20 AM Reply With Quote
Seems heavy for a crossflow engined car.
My Indy + Pinto weighed ~600kg
Have you had it weighed on a weighbridge to confirm?
