mikegsi
posted on 20/11/10 at 07:28 PM |
possibly oil pressure wiring?
as per my other post ive been having a dig around the wiring today on my rebuild, noticed a wire hanging under the engine, i think its a oil pressure
wire, but i cant seem to see where it would go.
this is where the other wire is attached too, im running a dry sump setup
any ideas where this wire should connect to?
ive not jacked the car up properly to have a good look underneath as yet
marcjagman
posted on 20/11/10 at 07:36 PM |
Is it by any chance an earth?
mikegsi
posted on 20/11/10 at 07:45 PM |
dont know mate, its just a wire hanging down
i thought it may be something to do with oil pressure as im sure some engine have 2 pressure sensors, theres a seperate light in the dash which im
presuming would illuminate if there was an issue with the pressure, and also possibly on startup as a 'self check' but its never lit up
yet..
adithorp
posted on 20/11/10 at 07:53 PM |
Is it the original BUSA loom (possibly modified for the car) or a custom loom? If it's the BUSA loom can you trace it in the wiring diagram?
http://jpsc.org.uk/forum/
mikegsi
posted on 20/11/10 at 08:08 PM |
erm, no idea mate
is the wiring diagram hosted on this forum?
Davegtst
posted on 20/11/10 at 08:40 PM |
Pretty sure my oil pressure switch wire goes into the busa's standard dash.
mikegsi
posted on 20/11/10 at 08:54 PM |
mine has an evodash setup with a 'standalone' light on the dash which im presuming is the oil pressure warning light, but its never
illuminated.
whereabouts on yours are the actual oil pressure sensors located? is there just the one or do you have 2?
Davegtst
posted on 20/11/10 at 09:25 PM |
There is one on the bottom of the engine pointing downwards on the clutch side.
mikegsi
posted on 20/11/10 at 10:12 PM |
Just the one? The same as per the picture above?
Cheers by the way![](/images//smilies/bigsmile.gif)
norfolkluego
posted on 20/11/10 at 11:31 PM |
Seem to remember when I bought a new oil sender unit earlier in the year some have two terminals, one being earth, others have only one and earth
through contact with the block, is it possibly a redundant earth after a sender change.
mikegsi
posted on 21/11/10 at 10:45 AM |
yeah, im gonna test it as an earth and see if the light comes on then off as it should
