Bass1st
posted on 23/11/10 at 07:47 PM |
16mm Oil Pipe
Anyone got an offcut of a rubber pipe with a 16mm diameter? I am reworking my oil cooling system and the 10mm diameter pipe I have is too small to go
over the connector on my oil cooler. If I have a 3" bit of 16mm pipe I can make a reducer. Don't really want to buy a meter if I can help
it!
Cheers.
Al
cliftyhanger
posted on 23/11/10 at 08:28 PM |
Are you sure it isn't 13mm??
And 10mm sounds very small for oilways.....
snapper
posted on 23/11/10 at 08:30 PM |
10mm is small for oil cooler pipes and will restrict flow, I am going up from 1/2" (13mm) to 5/8 (16mm)
I eat to survive
I drink to forget
snapper
posted on 23/11/10 at 08:31 PM |
I eat to survive
I drink to forget
Bass1st
posted on 23/11/10 at 10:49 PM |
It's the return from the cooler to the sump. The connector on the sump is definately 10mm. The connector on the cooler measures up at 16mm, but
I could probably get a 13mm on. 16mm is the outside diameter of the 10mm pipe I have, allowing me to make a reducer.
