Author: Subject: fuel cap and hose required
steve8274
posted on 5/12/10 at 06:16 PM Reply With Quote
hi all
can anyone tell me the best place to get fuel cap and fuel hose required to tank from?
needs to be suitable for IVA
had a quick check round but all seem very expensive.
maybe its just me being tight!!
thanks in advance
steve
russbost
posted on 5/12/10 at 06:52 PM Reply With Quote
Steve, if you mean an aero style cap they simply are expensive, so far as I'm aware I have them cheaper than anyone else at £69 (plus P & P), but not a cheap item I'm afraid
bob
posted on 5/12/10 at 07:39 PM Reply With Quote
Hi
Try these guys.
linky
I've used them a lot for fuel pipe into the tank and out plus they made up my brake pipes too.
Andi
posted on 5/12/10 at 09:20 PM Reply With Quote
The prices have always amazed me.
Maybe its because they are made of a special alloy that is mined only from underneath a killer
pterodactyl`s nest near the summit of K2 which only produces 2 grams of this precious metal every 5 years.
Either that or we are all getting ripped
steve8274
posted on 5/12/10 at 09:34 PM Reply With Quote
i dont understand why they are so dear. wouldnt be quite as bad if you got fuel hose to go with it but thats another twenty odd quid from what i can see!
any way rant over, i will just have to keep checking.
steve
russbost
posted on 5/12/10 at 09:52 PM Reply With Quote
Steve, how long fuel hose do you need?
[Edited on 5/12/10 by russbost]
steve8274
posted on 6/12/10 at 05:31 PM Reply With Quote
the fuel hose needs to be 2" to go onto tank and hose i have looked at is a 90 degree angle. approx 5" inches either side
thanks
steve
russbost
posted on 7/12/10 at 07:38 PM Reply With Quote
I only keep it in straight lengths unfortunately
RK
posted on 9/12/10 at 03:45 AM Reply With Quote
no reason you can't use one of those ally joins is there? Those are at CBS et al
mikegsi
posted on 10/12/10 at 11:50 PM Reply With Quote
I got some proper thick braided rubber pipe from a local land rover specialist, had to trim a little off each end but the bend was a perfect fit, I'll see if I still have the Britpart part number that was on the pipe
MikeR
posted on 11/12/10 at 12:44 AM Reply With Quote
instead of going to bed i've just found .......
http://www.retroanaconda.com/landrover/parts_books/90/7_brakes_fuel_air_exhaust_cool_heat_p581-718.pdf
which means the bit you're after is probably NRC9291 or NTC2338.
Have to say, fair play to the bloke who's set up that site. Its a mine of information.
