Author: Subject: bolt size
mikegsi
posted on 6/1/11 at 09:54 PM Reply With Quote
bolt size
ordered some black bolts for my harness's yesterday on ebay, after going through the bolts that i have i found that m10 was too small and M12 wheel bolts were just too big, so i ordered some M12 fine threads and they are also too big.
i have 2 bolts that fit and they are definately bigger than the m10 bolts i have, but have the same 17mm head, the m12's have a 19mm head.
is there such a size as m11 available for what i need, a quick search has only brought them up as head studs which isnt what im after
blakep82
posted on 6/1/11 at 09:59 PM Reply With Quote
7/16" UNF is the beast you need
________________________
mikegsi
posted on 6/1/11 at 10:03 PM Reply With Quote
cheers mate, i'll get some of them ordered in
blakep82
posted on 6/1/11 at 10:07 PM Reply With Quote
7/16" unf is like the standard seatbelt bolt size, still used on new cars i think. should be able to pick one up from a scrappy if you want to check first
mikegsi
posted on 6/1/11 at 10:12 PM Reply With Quote
pack of 50 on the bay for £7 posted, hardly seems worth the effort of trawling round scrappys, i'll get some bought then end up attempting to sell the rest cheaply
blakep82
posted on 6/1/11 at 10:14 PM Reply With Quote
what grade are they? they should be marked 10.8 (or whatever the imperial equivalent is, i can't remember)
mikegsi
posted on 6/1/11 at 10:18 PM Reply With Quote
didnt say the grade on the listing mate, just that they were high tensile ones....
posted on 7/1/11 at 09:28 AM Reply With Quote
Check before you buy them as Mr IVA will be sure to check them
wicket
posted on 8/1/11 at 09:16 PM Reply With Quote
I would be wary about 50 bolts for £7 in a safety critical situation. Probably come from China and and not the best quality, I would buy from a more reliable source. Mine came with the seat belts and have 3 equispaced bars on the head (SAE grade 5), see here
http://www.unified-eng.com/scitech/bolt/boltmarks.html
[Edited on 8/1/11 by wicket]
mikegsi
posted on 8/1/11 at 11:58 PM Reply With Quote
its an already IVA'd rebuild im doing so no issues there, however from a personal safety point i agree, i'll get some decent graded bolts, last thing i want is for them to snap.........
