Author: Subject: retoop running rich
joolsmi16
posted on 10/4/11 at 01:20 PM Reply With Quote
retoop running rich
Hi all, started my F27 for some summer fun to be let down with the engine running too rich so unable to have my fun!!!!!
The car was running fine when I stored for the winter but now loads of black some, plugs fouling (black) and will not tick over.. I did take the AFM off but made on difference..
So any help on what will course this engine to run rich, how to adjust or what part is at a fault
Jools
joolsmi16
posted on 10/4/11 at 01:50 PM Reply With Quote
RED TOP
Heading should read REDTOP engine is standard running std injection..
adithorp
posted on 10/4/11 at 02:13 PM Reply With Quote
Temp sender can cause that sort of problem. Have you done anything near it. I've seen then fail after just a bit of a knock.
http://jpsc.org.uk/forum/
posted on 10/4/11 at 02:17 PM Reply With Quote
Maybe a sticking fuel pressure regulator. Check fuel is actually coming back through the return to the tank when the pump is on.
joolsmi16
posted on 10/4/11 at 04:46 PM Reply With Quote
running rich
I've had the bonnet on and off a few time so could easily of knock something, if its only a temp sensor or fuel reg that could be the problem will look into them.
Jools
perksy
posted on 10/4/11 at 07:23 PM Reply With Quote
As said above, Coolant temperature sensor, Fuel pressure regulator
Also worth checking the TPS (Throttle position sensor) and Llambda sensor (If being used ? )
