jimthesail
posted on 15/4/11 at 07:34 PM |
De Dion
Ahoy !
Bought a kit of bits to make De Dion axles which appears to be a bit of a pot mess !
Can anyone tell me the origin of an irs system narrower than a Sierra.
The jig I have has two settings and I am not sure of the narrower track version.
Also can you use Sierra rear irs set up as a De Dion on the original Locost ?
Cheers Jim
Antnicuk
posted on 15/4/11 at 08:34 PM |
the fisher fury IRS system is sierra based but several inches narrower. Its the same width as an english axle and uses cut down sierra shafts.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
snapper
posted on 16/4/11 at 05:57 AM |
GavinC did this conversion on a book chassis using a standard width Sierra axle and DedDion, had to weld the trailing link bracket to the DeDion tube
further inboard to meet up with the chassis brackets.
Simples
I eat to survive
I drink to forget
