spdpug98
posted on 1/8/11 at 02:59 PM |
Push / Pull Cable
Just been out for a little drive in the car, but about 1 mile down the road from home the push/pull cable for my paddle shift snapped. Luckily for me
it snapped just as I changed into second and was therefore able to get home without too much of a problem
Now I have to get a new push/pull cable, I have sent an email to MNR but can anyone suggest an alternative supplier as this one has only lasted
approx. 1200 miles
[Edited on 1/8/11 by spdpug98]
My Blog: http://spdpug98.wordpress.com/
eddie99
posted on 1/8/11 at 03:02 PM |
I can get gear change cables at decent prices, I have found that they have lasted longer than any others i have tried. Do you know lengths and size
that you use? Then i can get you a quote
Kind Regards
Ed
spdpug98
posted on 1/8/11 at 03:18 PM |
quote: Originally posted by eddie99
Kind Regards
Ed
Cheers, I will get it off the car later on and measure it and get some pics
Johneturbo
posted on 1/8/11 at 04:27 PM |
I got a cable from local boat chandlers for about £20 they use them for throttle/control cables they use the same M5 rode ends
eddie99
posted on 1/8/11 at 04:36 PM |
I've tried one in the past and it snapped after being on track for about 10minutes
spdpug98
posted on 1/8/11 at 04:49 PM |
I have now got it off the car and the measurements are:
Green Section (between start of threads) 1065mm approx
End to End 1380mm approx (prior to snapping!!)
Small threaded end 20mm approx
If you need any other dimensions let me know, a couple of pics below:
Toniq-r
posted on 1/8/11 at 04:54 PM |
Cable - Tec 01623440398 Used them last week great service, on the plus I upgraded my cable so hopefully it wil last longer.
Johneturbo
posted on 1/8/11 at 05:03 PM |
I guess they must use different brands.... mines been on the road two years and i've done 2 trackdays with it
are you yanking it a bit to hard
ETA Teleflex is the brand i've used it's got a red outer sheath
http://marinestore.co.uk/teleflex-control-cables.html
i thought a few people on here used these
[Edited on 1/8/11 by Johneturbo]
spdpug98
posted on 1/8/11 at 05:23 PM |
Cheers, will see what Ed comes back with
