theduck
posted on 26/11/11 at 05:08 PM |
I presume this isn't right?
Forgive me if I'm missing something but I am new to carbs, please have a look at the video below. I think the throttle and choke cable linkages
aren't working correctly but maybe I am missing something?
http://www.youtube.com/watch?v=o0xAkxbJGXA&feature=youtube_gdata_player
Thanks in advance.
Greenie
posted on 26/11/11 at 05:21 PM |
This looks like a twin choke weber to me, the top two butterfly's are the chokes with the operating linkage located on the side as first
demonstrated, the second linkage he moves operates the the throttle butterfly's located in the bottom of the carb which are not shown......
SeaBass
The top are the choke flaps. The throttle butterflies are further inside the carb.
Looks like to works fine.
Your carb looks like it had an auto choke that has been DIYed to manual.
theduck
posted on 26/11/11 at 05:28 PM |
Excellent. I did think maybe there was a second set of butterlies but I just had them apart to fix the movement of the choke set as they were getting
stuck and didn't see them. They must be further in than I went. Glad to hear the operation Of the choke set is right. Can get these fitted when
the manifold gaskets turn up ![](/images//smilies/smile.gif)
ShaunB
posted on 27/11/11 at 09:35 PM |
Seabass is spot on, the top plates are choke plates and your carb has been fitted with a manual choke conversion kit. If you look down into the carb
you will see the throttle butterfly plates. One opens first and then the other, I think it's the one nearest the choke mech that opens
first.
Shaun.
theduck
posted on 28/11/11 at 11:04 AM |
Am I right in thinking as it's manual choke I don't need to run the coolant system to the manifold/carb?
theduck
posted on 30/11/11 at 03:47 PM |
Bump
Anyone confirm I don't need to run coolant connection to the carb?
ShaunB
posted on 30/11/11 at 04:18 PM |
Not to the carb if you have a manual choke. On a xflow there is a coolant passage from the head and through the manifold, which presumably on an
Escort would have fed the internal heater and acted as the thermostat bypass while the thermostat was closed. On my Westfield I have that connected
to the water pump top outlet, on the racing Locost it is blocked off but then I do not have a thermostat either.
Shaun.
theduck
posted on 30/11/11 at 04:41 PM |
Cheers. Now you've said that I think there may well be collant pipes attached to the manifold, would this be right on a pinto?
I'm getting there, slowly...
